straight vertical perimeter starting points? March 15, 2016 11:48AM |
Re: straight vertical perimeter starting points? March 15, 2016 12:35PM |
Re: straight vertical perimeter starting points? March 15, 2016 12:51PM |
Re: straight vertical perimeter starting points? March 15, 2016 03:20PM |
Re: straight vertical perimeter starting points? March 15, 2016 03:23PM |
Re: straight vertical perimeter starting points? March 15, 2016 06:11PM |
panire
"i will try to insert a thin tube as outer layer, so maybe slic3r can interpret it as one object through that."
yup that was the solution, i added a very thin tube "0.03mm" to the outside, so slicer interpreted it right.
Re: straight vertical perimeter starting points? March 16, 2016 01:52AM |
Re: straight vertical perimeter starting points? March 16, 2016 01:01PM |
Re: straight vertical perimeter starting points? March 16, 2016 01:17PM |
chris33
so the threaded rod gather not a proper lead/ball screw is it fixed at the top or open? if its fixed and the thread not perfectly straight, thats why orignal prusa wasnt captive using threaded m5 bar
