straight vertical perimeter starting points?
Posted by panire
March 15, 2016 11:48AM
Dear Community winking smiley
Is there a way to always start the perimeters on the same vertical position (i cant get them aligned - see images)?
I tried the advanced settings (seam position: nearest, random aligned), but this options dont get it righ. quite well.
Thanks for a short suggestion (a link would also be ok, as i seem to bee too stupid to find information about that yet).
Greetings and thank you
Edited 1 time(s). Last edit at 03/15/2016 11:48AM by panire.
open | download - picture639.jpg (58.3 KB)
open | download - picture646.jpg (259.3 KB)
open | download - picture648.jpg (218 KB)
open | download - asd.png (2.7 KB)
Re: straight vertical perimeter starting points?
March 15, 2016 12:35PM
In the first picture I think I am seeing pretty severe Z wobble- or was that an intentional part of the design?
In the rest I see the seam moving around- if you print just a cylinder or cube and do not change anything from top to bottom- that means no changes in area/size of anything, variations in infill density or pattern, etc.- it should keep the seam in a straight line. As soon as anything about the shape changes, the gcode planner changes the tool path and the location of the layer start with it.
I don't believe there is any way in Slic3r to force the seam to a specific position even on the simplest prints.
March 15, 2016 12:51PM
Ok I see.
i will try to insert a thin tube as outer layer, so maybe slic3r can interpret it as one object through that.
about the z-axis:
Its printed on a 250$-Geeetech printer for, the z-axis threaded rods doesn't sit that stiff inside theyr threads and they are even a bit bended (i guess thats ok for the priceclass). I still like the print in general, but really thanks for being that exact about it - I will have a look on how to improve that. :-)
thank you
March 15, 2016 03:20PM
"i will try to insert a thin tube as outer layer, so maybe slic3r can interpret it as one object through that."
yup that was the solution, i added a very thin tube "0.03mm" to the outside, so slicer interpreted it right.
March 15, 2016 03:23PM
in any kind of 3d object i would always prefer to have the retractions of all layer changes on the backside and not on a random vertical position. I am wondering why there is no implementation for setting its position.
Edited 1 time(s). Last edit at 03/15/2016 03:24PM by panire.
March 15, 2016 06:11PM
panire
Can you post a screen shot showing what that looks like?
Thanks!
Edited 1 time(s). Last edit at 03/15/2016 06:11PM by the_digital_dentist.
March 16, 2016 01:52AM
so the threaded rod gather not a proper lead/ball screw is it fixed at the top or open? if its fixed and the thread not perfectly straight, thats why orignal prusa wasnt captive using threaded m5 bar
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
March 16, 2016 01:01PM
"Can you post a screen shot showing what that looks like?"
Have a look - attachment
I have no idea how slicer reads the stl-file. i am sure its highly dependent on the way of how the stl file is read.
in this case i exported the stl file from freecad.
Edited 1 time(s). Last edit at 03/16/2016 01:06PM by panire.
open | download - perimeter.png (174.8 KB)
March 16, 2016 01:17PM
chris33
The wobble has quite the same size like the threads itself.
Its not really free, it touches the acrylic a bit. shall I make the hole of the acrylic bigger so the threaded rod hangs free?
Edited 1 time(s). Last edit at 03/16/2016 01:19PM by panire.
open | download - picture687.jpg (206.6 KB)
open | download - picture684.jpg (374.7 KB)
