Minor detail that is upsetting me
Posted by Carlcox89
March 22, 2016 09:40PM
Hi everyone
I've been improving my printings but have some final issue that's bothering me and I am not able to figure out what's going on.
This print (image attached) was printed using 0.1mm layer height and 100% infill.
I am using Repetier host with Cura Slicing...
Used 1.2 Shell thickness
1.2 top/bottom thickness
40% infill overlay
As you see in the pictures there are fails near the holes and more far from a hole. The top of the print (that highest part) however came flawlessly...so I discard top layer thickness right ?
Any sugestions / help would be very much appreciated
kind regards
open | download - 20160323_012839.jpg (570.6 KB)
open | download - 20160323_012851.jpg (585.3 KB)
open | download - 20160323_013237.jpg (412.4 KB)
Re: Minor detail that is upsetting me
March 22, 2016 10:01PM
Part of the problem is under extrusion (based on the gaps in the top solid fill), and the gaps around part of the circle suggest a degree of back-lash. The holes you arrowed in 20160323_013237.jpg are a bit of a mystery. In one case it looks like the entire line gradually petered out before the hole happened - maybe a slipping extruder gear?
March 25, 2016 09:38AM
Solved most of the gaps by increasing extruder multiplier but cant fix the gaps between holes and infill
Extruder gear doesnt seem to be slipping
March 29, 2016 01:58AM
I have similar defects at times, sometimes when the filament pops, I'm assuming because of moisture in the filament it will leave these gaps. Also, I notice that if at the times the filament has to yank on the spool to get filament extruded, that it leaves less filament at that spot. I also of a bowden tube that has way more friction than I'd like and it gets worse if there is a lot of retraction, this makes it harder for the extruder to extrude, but that would show a little more continuous problem of gaps and such, so I'd suspect something minor restricting extrusion.
