Extruder reverse direction in middle of the print - Problem
Posted by Koby_88
April 14, 2016 01:17PM
I have problem with my extruder motor. Printer starts print normal, but in some time he change direction of extrusion.... I dont know what is wrong with my printer pls help !!!
Re: Extruder reverse direction in middle of the print - Problem
April 14, 2016 01:54PM
are any of the contacts on the board loose or shorting? it has to be that.
or Demons...your on your own for that though...
April 14, 2016 01:57PM
No everything is ok, no shorting, or demons or something like that grinning smiley I use marlin firmware, cura software and ramps board if that helps....
April 15, 2016 10:12AM
then im thinking maybe a slicing issue with cura. have you tried a G-code from Slic3r or anything?
April 15, 2016 06:09PM
Let me guess:
The print goes fine for a while, then you see some unwanted movement and either with that movement or right after the extruder goes nuts?
If that is the case I would suspect comnnunication problems.
Baud rate not high enough or not matching firmware settings, USB cable too long, too many other USB devices in use....
April 15, 2016 10:06PM
Can you attach the same exact GCODE file that causes the problem when printed? We would like to rule out the slicer as the error.
Master Tinkerer
April 15, 2016 11:17PM
My machine has done this twice for two reasons, First time was a failing stepper driver, second time was a loose connection in the wiring.
