Extruder reverse direction in middle of the print - Problem
Posted by Koby_88
April 14, 2016 01:17PM
I have problem with my extruder motor. Printer starts print normal, but in some time he change direction of extrusion.... I dont know what is wrong with my printer pls help !!!
Re: Extruder reverse direction in middle of the print - Problem
April 14, 2016 01:54PM
are any of the contacts on the board loose or shorting? it has to be that.
or Demons...your on your own for that though...
April 14, 2016 01:57PM
No everything is ok, no shorting, or demons or something like that grinning smiley I use marlin firmware, cura software and ramps board if that helps....
April 15, 2016 10:12AM
then im thinking maybe a slicing issue with cura. have you tried a G-code from Slic3r or anything?
April 15, 2016 06:09PM
Let me guess:
The print goes fine for a while, then you see some unwanted movement and either with that movement or right after the extruder goes nuts?
If that is the case I would suspect comnnunication problems.
Baud rate not high enough or not matching firmware settings, USB cable too long, too many other USB devices in use....
April 15, 2016 10:06PM
Can you attach the same exact GCODE file that causes the problem when printed? We would like to rule out the slicer as the error.
April 15, 2016 11:17PM
My machine has done this twice for two reasons, First time was a failing stepper driver, second time was a loose connection in the wiring.
