Printing 2cm cube and getting this !!!
Posted by Sanjaykray
June 05, 2016 12:31PM
I am using my scratch built paisa i3 (ramps1.4+mega-latest marlin) while trying to print my first print the problem is that every next layer of print gets printed on totally new place (x axis) attached is the result of 2cm cube .I am using slic3r.Please help guys.
Newbie with scratch built Prusa i3 with Ramps 1.4 , arduino mega using marlin firmware.
open | download - IMG_20160605_215206_1465143878235.jpg (115.2 KB)
open | download - IMG_20160531_131952_1465143942411.jpg (223.7 KB)
Re: Printing 2cm cube and getting this !!!
June 05, 2016 01:01PM
You may not have a high enough stepper current to keep it from losing steps or it's set to high & it's overheating or a mechanical problem in that something it preventing the x axis from moving properly.
June 05, 2016 03:46PM
I've adjusted the pots on stepper drivers,lubricated the rods and belts are also quite ok .Very confused may be someone help??
June 05, 2016 09:40PM
I would guess binding on the X axis. If you take the belt off the motor pulley how easy does the carriage move?
Newbie with Folgertech 2020 i3.
June 06, 2016 02:19PM
There are many possibilities: [reprap.org]
June 06, 2016 03:10PM
Thanks for the pointer James.
June 07, 2016 08:08PM
I had that problem, but not that serious. I found that the cables going to the X stepper motor, were very close to other cables and according a and electronic engineer I have as a friend, this could cause "parasitic current" into the cable. I isoleted those cables, and the problem desapeared.
June 07, 2016 11:59PM
I'll try that,thanks Tinchus
June 15, 2016 05:12AM
Resolved !!!
Just changed the stepper driver and everything is fine now (X axis). Thanks everyone for your helpful suggestions.
June 15, 2016 03:47PM
Hey guys check www doing it 3d .com and find d printing projects
