Help me improve printing quality
Posted by mikiskis2
June 08, 2016 10:43AM
Hello, I have 3D printer for a while but still cannot achieve high quality prints.
Issue 1: Gaps
What should I change to solve it?
Issue 2: Filament blobs. After few layers of printing this happens:
Is it possible that these blobs is a result of low quality filament (I am using PLA).
Re: Help me improve printing quality
June 08, 2016 11:28AM
Make sure your extruder is calibrated and it isn't losing steps or slipping.
June 08, 2016 11:48AM
Might need to print hotter.
What temps and speeds are you printing at?
Do you have the right size nozzle in your slicer software that matches what the printer has?
June 08, 2016 12:01PM
It looks like under extrusion all around to me. Calibrate the extruder , make sure the nozzle isn't clogged, and then tempreture and speed . I run 30mms at 175 and 100mms at 190 with a .4mm nozzle typically.
June 08, 2016 07:22PM
Like said above, it seems like your extruder skips or your hotend clogs.
When it fully stops extruding and you stop the print, can you still extrude and pull out your filament without a problem?
June 12, 2016 06:03PM
You may want to check your stepper voltages.
