First to second layer adhesion issue June 09, 2016 06:04PM |
Re: First to second layer adhesion issue June 09, 2016 07:35PM |
Re: First to second layer adhesion issue June 10, 2016 07:43AM |
Re: First to second layer adhesion issue June 10, 2016 09:37AM |
ggherbaz
use a layer height not bigger than 60-70% of your nozzle size.
MCcarman
Check the gap between the bed and nozzle. Put this value in your slicer. Your first layer seems a lot larger than the others so I am wondering if you are just dropping filament on the bed. If you are deliberately over extruding the first layer as is often suggested you may mask the issue.
Re: First to second layer adhesion issue June 10, 2016 11:16AM |
Re: First to second layer adhesion issue June 10, 2016 08:30PM |
Re: First to second layer adhesion issue June 11, 2016 12:26PM |
Re: First to second layer adhesion issue June 12, 2016 09:00AM |
