another ABS print question
Posted by deaconfrost
June 23, 2016 04:06PM
I'm thinking this is due to I haven't put the printer in an enclosure after I move house, and a bit too fast maybe
perfect first layer, others not so much, but over all its smooth
perfect first layer no lift
Edited 1 time(s). Last edit at 06/23/2016 04:07PM by deaconfrost.
Re: another ABS print question
June 23, 2016 05:03PM
second print is much better but I broke the bottom of the cube trying to get it off
June 23, 2016 05:32PM
ABS success no heat bed
Edited 1 time(s). Last edit at 06/23/2016 05:33PM by deaconfrost.
June 23, 2016 07:29PM
You can print all sorts of single-walled parts using ABS without an enclosure. Here's a 250 mm tall single-walled ABS vase printing:
[milwaukeemakerspace.org]
The trouble starts when you print objects that are a little more solid. For that you must have a warm enclosure.
Edited 2 time(s). Last edit at 06/23/2016 07:32PM by the_digital_dentist.
