ZIG ZAG PRINTS! HELP
Posted by Omniaa
July 20, 2016 08:25AM
hey everyone,
I am new to this 3D printing community, i have made my first PLA 3d printer. I cant find my problem on the internet and its really weird. When i try to print a rectangle (or any shape for that matter), layers are getting shifted at periodic intervals. it's forming wavy structure when it should be straight!! I am using Repetier Host and Repetier Firmware. I directly print from the SD card on the Full graphic smart controller (reprap discount). NO sticking issues. And i dont think it can be a belt slipping problem, this is clear i guess from the pictures i have attached, the print is leaning to say left side for some layers and then leaning right for some layers, and the whole pattern is being repeated throughout the object height. All the objects have the same wavy feature. there is no such wavy feature in the stl file. I have printed a hollow calibration cube of 20mm but it has shown same wavy patterns at same height. PLEASE HELP! Thanks
It was supposed to be rectangle of 25x15x30..:
A spiro coaster i printed, since height of object is less, wavy nature is not prominent other than edges
Re: ZIG ZAG PRINTS! HELP
July 20, 2016 08:09PM
I don't think it will be a bended Z axis neither, most likely is on the steppers (if you are absolutely sure isn't the belts), have you check the vref on your stepper driver? Also what speed are you trying to print at?
Do a little test and increase non printing speed at 3600 to 4000 mm per min and move X and Y about 100mm on any direction, see if the stepper skips or if it makes any noises, check that it traveled the correct distance. One more thing that it can be is that your carriages are binding due to asymmetrical rods.
July 20, 2016 08:24PM
Check that the pulleys are tightly attached to the stepper motors.
But the period of the wave seems a bit long and regular for it to be mechanical. Also the waviness is on all sides of the object, not just 2, so it would have to be the fault in 2 axes. I wonder if this is somehow associated with infill? Maybe you've set the external perimeters to 0 in your slicer so you're only seeing infill?
Are you using automatic bed-levelling? If you are, then errors in the Z axis motion can result in X/Y errors in the output. But I wouldn't expect it to be as extreme as this.
What slicer are you using? Have tried a different one?
What type of printer is it? Cartesian? Delta?
July 20, 2016 09:04PM
Those are the best prints ever. Please tell me you're just trolling us. If not, a video might help.
July 21, 2016 03:22AM
That was my first thought James, the wave is so bad it's good.
July 21, 2016 12:24PM
I would build another printer and keep this one as is. Prints look amazing.
July 27, 2016 03:58AM
Thankyou for responding and hey, I am not trolling grinning smiley
i dont know why those waves are coming. after posting my problem here and tried to rebuild it, and the errors have reduced but are still at same height.. And here's the picture of my 3d printer, its what i have made at home, so looks a bit messy grinning smiley
last week's print and this week, a bit improved.
@ggherbaz : i will try that. thankyou
@frankvdh : yaa the pulleys are all tight, infill is not set to zero. it prints external layers slowly and quite fine. I use slic3r. i havent tried other slicer but i will check.
July 27, 2016 06:51AM
You have four screws lifting the bed but I don't see any guide rails in the Z axis to constrain the bed's lateral motion. The ends of the screws are just standing in free air, with nothing to constrain them either.
It bothers me to see tape wrapped around the extruder- it that all that's holding it in position?
The X axis belt looks quite loose.
When something prints with such large and obvious defects, the source of the problem should be visible if you watch the printer while it is running.
July 27, 2016 07:19AM
Thanks for responding. yaa i have made a frame that i am going to attach to free ends of lead screws. and noo the extruder is not held by that grinning smiley screw are attached on the inside and a metal plate as well holding all of it together. and will have belt tighter on other axis as well. I will fix the free ends and check if the problem is gone,, thanks smiling smiley
July 27, 2016 08:09AM
Omniaa
Lead screws are for providing motion in the axial direction, they are not intended for constraining movement in the radial direction. You need to add some linear motion components to do that, either smooth rods or linear rails.
August 07, 2016 10:07AM
thankyou so much, i made a new printer with a better bed arrangement, which has two lead screws and 2 smooth rods... now its all working fine.. it was the bed's wobbling that was creating all the problems..
August 07, 2016 11:28AM
That's great news, well done for sorting it out. And thank you for letting us know smiling smiley
October 03, 2016 10:29PM
sigxcpu
What in the world are you guys talking about when you say those are good print's?
October 04, 2016 06:56AM
Just a bit of fun. Normally when someone asks about Z wobble the defects are small and rather random. The huge smooth waves on these prints are like nothing I had ever seen before and should certainly be kept as a remarkable example of a printing artefact.
October 04, 2016 11:04AM
Aha i see xd
Well i am about to open a topic myself about something that looks like z wobble winking smiley
