all was working perfect, and I swap over from Ramps 1.4 Mega2650 to Radds 1.5 Arduino Due (genuine not copy)
everything seems perfect on first flash except when retracting, extruder motor skip badly, no current changes from ramps to radds, had a look in the firmware max speed was 50mm/s on extruder so I reduced it to 25mm/s and it all seems good for printing except at the start of the print wher it retract before print, which I dont know why, never did it before, and when using filament change option, it skips very bad, I ended up pulling out the filament and feed it by hand instead, other than that, it prints beautifully and more quiet, seems a little faster
also I have no way of controlling from repetier host, just from lcd alone
its running latest repetier firmware
Edited 1 time(s). Last edit at 07/30/2016 06:05PM by deaconfrost.
