temperature fluctuation
Posted by moonshine
August 28, 2016 11:37PM
What could cause this kind of temperature fluctuation ? Bad thermistor ? Bad connection between thermistor and board ?
Of course the print failed with " Error: MAXTEMP triggered, system stopped! Heater_ID: 0 "
This has started after a pause of a few week of not using the printer...
It's a custom i3 running Marlin on a MKS Gen1.3 with ATC Semitec 104GT-2 thermistor
Prusa i3 w/ Marlin firmware | Simplify3D | OctoPrint / Nautilus
Re: temperature fluctuation
August 31, 2016 04:19PM
did you try to run a PID auto tune? are there any fans or ac units close by that could be cooling the thermistor? could be gremlins... look into it and get back to me
September 01, 2016 12:16AM
i did ran pid tuning . that was when I first installed the heater.
the sudden drop of temperature (20-40C) between 2 consecutive readings can't be caused by a fan (by the way, theres no fan running except the heatsink cooler) )
any other ideas ?
PS checked for gremlins. none found. YET!
UPDATE: strangely, this only happens while printing! I turned on the heater and it stayed at constant temperature without much fluctuation (at least in acceptable <1C tolerance ). what can cause it to fluctuate when it prints.. ?
Edited 1 time(s). Last edit at 09/01/2016 03:56AM by moonshine.
September 01, 2016 04:52AM
This explains it... The movement of the head during printing would cause the bad connection to give bad readings...
Note: No gremlins were spotted before, during or after the incident.
