PLA Jamming after a 30 seconds
September 04, 2016 07:49PM
here is my problem. My printer can print ABS fine, when I load my PLA in it extruders for about 30 seconds then jams in the hotend. I think the PLA is melting too early in the barrel. Any thoughts?
Edited 1 time(s). Last edit at 09/04/2016 07:51PM by JMAPsci.
Re: PLA Jamming after a 30 seconds
September 04, 2016 10:04PM
What hotend you have? Does it have a cooling fan to cool the heatsink section? What temperature you are using?
September 05, 2016 11:05AM
If its a all metal hot end that jam could just be more resistance than your extruder can currently handle. PLA gets warm and sticky in the cold end but if you have a strong extruder and a tight tensioner you can power through this. Alternatively you can try to clean out your heatbreak/hotend and put a bit of olive oil in and bring it up to around 240 C for a few minutes, this should reduce the friction (i do this cooling fan off so the cold end heats as well)
September 08, 2016 07:34AM
Try without retraction
