Uneven surface problem September 17, 2016 01:20PM |
Re: Uneven surface problem September 17, 2016 01:42PM |
Re: Uneven surface problem September 17, 2016 02:47PM |
Re: Uneven surface problem September 17, 2016 03:47PM |
Re: Uneven surface problem September 17, 2016 05:53PM |
Re: Uneven surface problem September 18, 2016 08:27AM |
Re: Uneven surface problem September 18, 2016 08:47AM |
Re: Uneven surface problem September 18, 2016 09:05AM |
Re: Uneven surface problem September 18, 2016 10:20AM |
Re: Uneven surface problem September 18, 2016 01:10PM |
Re: Uneven surface problem September 18, 2016 01:15PM |
Re: Uneven surface problem September 18, 2016 03:43PM |
Re: Uneven surface problem September 18, 2016 08:01PM |
Re: Uneven surface problem September 19, 2016 03:14AM |
Re: Uneven surface problem September 19, 2016 09:31AM |
Re: Uneven surface problem September 19, 2016 09:58AM |
Re: Uneven surface problem September 19, 2016 11:35AM |
Re: Uneven surface problem September 19, 2016 02:54PM |
the_digital_dentist
You've apparently never used linear guides. There's absolutely no play in those bearings. The rail is attached to a piece of 2020 or tubing which makes it even stiffer than it normally is. The X axis is very rigid and uses a single relatively short belt that appears to be 9 mm wide. It is the last place I'd expect to see a problem in this build. The Y axis uses a shaft to drive both ends of the X axis. That shaft is belt driven. Maybe there's some play/stretch in the belts or twist in the shaft that drives the axis. Maybe the two Y axis belts at the ends of the X axis are not equally tensioned allowing one side to lag the other slightly.
Re: Uneven surface problem September 20, 2016 02:06PM |
JamesK
Is the Z dimension of your test-cube what you expect it to be? Having just spent the weekend fighting my Z axis I have missed steps on my mind. On X and Y missed steps are immediately obvious, not so much on Z. It can sneak up on you and causes artefacts not unlike those you show.
chris33
i would say nozzle one of the pictures shows that in misses part of the layer. also what material you printing if pla make sure fan hitting on the layer
DaGameFace
The more I look at this the more I think that it has to be wobble in the mechanics. Not the frame, that printer looks extremely well built. But, you have so many belts, that I there is bound to be lash in them. Not to mention your x axis, looks like it would be likely to have a tiny bit more give than traditional smooth rails and bearings.
This would explain why one of the faces is fine, it is just after a z layer change meaning that during the change the belts all stop and the lash goes away, it gets moved in one direction which it does fine. But then when it needs to change direction its momentum effects the perimeter because the belts have tiny amounts of play in them. Thereby leaving imperfections in the other 3 sides.
I find it kinda funny, that a machine as well built as that can suffer from outer perimeter problems while my really wobbly i3 acrylic frame prints beautiful parts. (though they can't be nearly as square and true as anything your machine produces)
the_digital_dentist
FA-MAS
Would you also post pics of your machine?
Edit: After watching the youtube video. I'd second Dentist's last suggestion about equal belt tension on the Y
Also for the Z, you have 4 linear rods, with 2 lead screws at the center on both sides. Does the bed seesaw at all?
DaGameFace
Yeah it was the Y that really caught my attention, a long fairly thin shaft can twist, plus 3 belts? sounds like a likely source of lash. And yeah, I was indeed unfamiliar with linear guides.
SO, the x axis is out, Y, Maybe? I thought that Z axis was insanely overbuilt, would surprise me if that is where his problems lay. Just for the hell of it could you print a 20x20 cylinder? (with the circular base as the bottom and top layer)
Re: Uneven surface problem September 20, 2016 02:09PM |
Re: Uneven surface problem September 20, 2016 02:45PM |
Re: Uneven surface problem September 20, 2016 05:25PM |
Re: Uneven surface problem September 20, 2016 05:41PM |
Re: Uneven surface problem September 23, 2016 08:31AM |
Re: Uneven surface problem September 23, 2016 01:16PM |
Re: Uneven surface problem September 23, 2016 01:23PM |
Re: Uneven surface problem September 23, 2016 01:56PM |
Re: Uneven surface problem September 23, 2016 02:04PM |
Re: Uneven surface problem September 23, 2016 04:05PM |
MosfetN
Yesterday i have changed the whole hotend assembly from genuine E3D V6 to old one peek J-head with 0.5mm nozzle.
Results are surprising the surface is now much smoother.
Re: Uneven surface problem September 23, 2016 05:01PM |
