Quality of eSun PLA filament?
October 03, 2016 12:46AM
I have run into horribly brittle parts of eSun PLA filament.
Layer separation on a printed part.
Layer height 0.2 mm, infill 40%, perimeter 3, temperature 210 C
I thought the red filament was a bad batch so I opened up a green filament.
Layer height 0.2 mm, infill 40%, perimeter 3, temperature 205 C
When I was removing the screw, it broke. angry smiley
The cube's wall thickness is 0.8 mm without infill. The screw's diameter is 11.15.
I could break screw with finger pressure.
Simple math gives surface area of two objects: cube (25.60 mm^2), screw (103.86 mm^2)
The screw should have 4 times stronger than the hollow cube. To me the screw feels twenty times weaker than the cube.
Temperature cube test
Edited 2 time(s). Last edit at 10/03/2016 09:31PM by janpenguin.
Re: Quality of eSun PLA filament?
October 03, 2016 09:56PM
Do prints with filament of different suppliers look the same, in other words is the problem just the strength?
I have a bunch of old esun spools laying around, abs though, i only tried one yet, and the quality is fine.
October 03, 2016 10:36PM
I'm using eSun PLA.
Don't buy their "PLA"
It is rubbish and brittle. As you noticed you can just twist the part and delaminate layers.
Get their "PLA+" which is stronger.
October 05, 2016 01:05AM
@Govahnato
It was bad filaments.
@Veesta
The third filament was okay. I sent two spools of filament to the seller in exchange of new ones.
If one of the filaments turns out bad, I will get other brand.
I made a simple cube to test new filament.
[www.thingiverse.com]
