Prusa i3 intermittent extrusion October 21, 2016 07:16PM |
Re: Prusa i3 intermittent extrusion October 21, 2016 07:25PM |
Re: Prusa i3 intermittent extrusion October 21, 2016 07:30PM |
Re: Prusa i3 intermittent extrusion October 21, 2016 07:37PM |
Re: Prusa i3 intermittent extrusion October 21, 2016 07:40PM |
Re: Prusa i3 intermittent extrusion October 21, 2016 07:50PM |
Re: Prusa i3 intermittent extrusion October 22, 2016 02:02AM |
Re: Prusa i3 intermittent extrusion October 22, 2016 06:09AM |
Re: Prusa i3 intermittent extrusion October 22, 2016 08:10AM |
Re: Prusa i3 intermittent extrusion October 22, 2016 08:20AM |
Re: Prusa i3 intermittent extrusion October 22, 2016 08:50AM |
Re: Prusa i3 intermittent extrusion October 22, 2016 08:51AM |
Re: Prusa i3 intermittent extrusion October 22, 2016 09:01AM |
Re: Prusa i3 intermittent extrusion October 22, 2016 09:49AM |
Re: Prusa i3 intermittent extrusion February 19, 2017 11:46AM |
Re: Prusa i3 intermittent extrusion February 20, 2017 03:51AM |
ethicalfive
Geeetech uses the cheapest, crappiest plastic extruder head. Just take a look at the geeetech forum complaints about under extrusion.
If its the mk8 plastic extruder head check the tension of the arm, if the spring is weak, add shimies to compress it more. If its the heavy duty spring, dissassemble the extruder head and examine for cracks. Mine came with a heavy duty spring which had put so much force on the idler wheel it had cracked the part holding the axle. The part was hidden between the stepper and the tension arm so i didnt diagnose it for a long time. Ive removed some of the plastic which sets the gap to give enough tension even with the cracked part while i wait for a new metal extruder head.
This problem really sucks because there are so many legitimate problems which can cause your problem you can spend forever following those without realising the product is faulty by default.
Re: Prusa i3 intermittent extrusion February 20, 2017 03:58AM |
Re: Prusa i3 intermittent extrusion February 20, 2017 06:10AM |
Re: Prusa i3 intermittent extrusion February 20, 2017 10:00AM |
obewan
Thats a nice extruder,exactly what i use. Make sure you adjust the tensioner bolt so that the brass toothed wheel bites into
the filament enough so it does not slip.
Heat the bed and nozzle,then move the nozzle to centre of the bed and at Z0 you should have about a 'fag' paper distance between nozzle and bed(adjust Z home if nessesary)
With layer height set at 0.2mm, set initial layer to 0.3 or 0.35 and initial extrusion width to about 130% (set in the slicer)
I find printing circles on 1st layer can be problamatic at times and need to be printed quite slow(10 -20 mm/s seems to work for me)
Re: Prusa i3 intermittent extrusion February 20, 2017 06:32PM |
Re: Prusa i3 intermittent extrusion March 01, 2017 08:58AM |
Re: Prusa i3 intermittent extrusion March 02, 2017 05:57AM |
Re: Prusa i3 intermittent extrusion March 02, 2017 06:48AM |
Re: Prusa i3 intermittent extrusion May 12, 2017 03:13PM |
Re: Prusa i3 intermittent extrusion May 13, 2017 02:40AM |
Pelle13
Bad news... Anything else I print with 0.2 layer height still being a disaster...
Re: Prusa i3 intermittent extrusion May 13, 2017 03:29AM |
Re: Prusa i3 intermittent extrusion May 13, 2017 06:22AM |
Re: Prusa i3 intermittent extrusion May 13, 2017 04:44PM |
