Blobs and holes on outer perimeter November 17, 2016 03:37PM |
Re: Blobs and holes on outer perimeter November 17, 2016 09:02PM |
Re: Blobs and holes on outer perimeter November 18, 2016 11:54AM |
ggherbaz
Your problem isnt in the slicer but in your printer, most likely is the bowden system you are using. You need to increase the extruder torque, reduce the lenght of the tube and also probably use a tube with an smaller inner diameter, the less your filament can flex or snake inside the tube the better.
You can try to increase the extruder feedrate to see if helps, also get rid of any wipe, restart and coasting settings in S3D, those settings works good on a direct drive but not on bowden.
