Heating problem when printing from SD
Posted by Shachar85
November 25, 2016 03:44PM
Hi
I've been having some trouble to print from SD.
When I try to print from SD, or even set the nozzle temperature from the RAMPS menu - the nozzle temperature can't get to stabilize and the temperature jump 4-5 and sometimes even 10 degrees from a reading to the next reading.
I thought it was a matter of PID setting, but when I tried to set it with USB cable, the temperature rises perfect and very stable.
That rules out hardware problems as well.
The problem only accurs when I'm printing standalone - with no PC connection.
Anyone experienced such problem before? Any ideas?
Re: Heating problem when printing from SD
November 25, 2016 04:10PM
First, look at the gcode on the SD card and make sure it looks OK. Next, format that SD card and put a fresh copy of the gcode on it and try again. If that doesn't work, try a different, freshly formatted SD card. Make sure you eject the SD card from the computer before you physically pull it out of the computer.
November 26, 2016 02:18AM
The problem also happen the same way when I try to heat things up through the ramps menu.
Even with no SD card at all.
So I think the SD card is innocent
November 26, 2016 06:39AM
Little bit more details. Might help for solution
I tried to warm the extruder with USB connected, then, when it is warm enough, switch to standalone mode and print from SD.
When I turned on the system (after the extruder already warm), I noticed the nozzle temperature is very not stable.
Even without trying to heat the nozzle. Just reading the temperature.
When it was connected with USB, the temperature was very stable.
I can't understand what might cause such behavior
November 26, 2016 08:37AM
Check the 5V regulator on the controller board.
November 26, 2016 01:52PM
Might be the something to do with it. I'll check it tomorrow.
I did some modifications lately in the 5v area.
What made you think of it?
November 27, 2016 01:16PM
An update-
The arduino was powered from the PSU (PC PSU).
I power it now with external 9v PSU and everything works perfectly smooth.
It seems that it was a matter of power consumption.
Thanks for the tip
