Under extrusion on start December 12, 2016 04:51PM |
Re: Under extrusion on start December 12, 2016 07:29PM |
Re: Under extrusion on start December 12, 2016 07:42PM |
Re: Under extrusion on start December 13, 2016 05:21AM |
Supermec
I don't use the slicers that you mention so I am not familiar with their settings. You say that you have a Bowden extruder, how long have you had it? I understand that with Bowden extruders the filament snakes from side to side in the feed tube. This means that the length of filament between the drive and the nozzle must be longer than the actual length before the pressure required to push the filament through the nozzle is generated. Could it be something to do with your retraction settings together with the Bowden extruder?
Floyd
Mine does the same. I have to add material after a retract otherwise it runs about 20mm before it starts extruding after a retract. Its a setting in most slicers
Re: Under extrusion on start December 13, 2016 10:00AM |
