Issues Using Stainless Steel Nozzle December 13, 2016 02:29PM |
Re: Issues Using Stainless Steel Nozzle December 13, 2016 03:31PM |
Re: Issues Using Stainless Steel Nozzle December 13, 2016 05:39PM |
Srek
Stainless steel transports heat a lot worse than brass. If the thermal sensor isn''t extremely close to the opening of the nozzle you will get wrong temperatures and the actual temperature of the nozzle can be a lot lower than shown.
Re: Issues Using Stainless Steel Nozzle December 13, 2016 05:45PM |
Re: Issues Using Stainless Steel Nozzle December 13, 2016 07:40PM |
ggherbaz
From that picture, you have the nozzle too far out, that will make things worse, you need to screw in the nozzle all the way in and I would recommend you to cover the heater block with fiberglass or ceramic fiber.
SS nozzles will take longer to heat up, but once heated will be more stable than the brass ones, don't raise the temperature but rather let it heat a little longer before start printing.
Re: Issues Using Stainless Steel Nozzle December 13, 2016 11:46PM |
Re: Issues Using Stainless Steel Nozzle December 14, 2016 12:12AM |
