Heatbed taking hours to heat up March 04, 2017 11:27AM |
Re: Heatbed taking hours to heat up March 04, 2017 12:03PM |
Re: Heatbed taking hours to heat up March 04, 2017 08:32PM |
Re: Heatbed taking hours to heat up March 04, 2017 10:38PM |
Re: Heatbed taking hours to heat up March 05, 2017 06:51PM |
Re: Heatbed taking hours to heat up March 06, 2017 06:31PM |
Re: Heatbed taking hours to heat up March 06, 2017 07:08PM |
Re: Heatbed taking hours to heat up March 06, 2017 07:53PM |
Re: Heatbed taking hours to heat up March 07, 2017 05:11PM |
djlapan
So I tested my output to the heat bed. I am getting 9.96 Volts and the resistance is around 1.8 to 2 ohms. I've double checked to make sure that I have wired the heat bed correctly through the wiki, which I have wired correctly. Both power leads coming into the RAMPS 1.4 are reading 12.01` Volts and 11.97 Volts. I did tin the wire ends that are coming from the head bed to the RAMPS. Do I need a solid state relay. My Power supply is a 400 watt with one positive +12V and one negative -12V (blue wire(which I am not using)).
What could be the issue?
Re: Heatbed taking hours to heat up March 10, 2017 07:39AM |
Re: Heatbed taking hours to heat up March 10, 2017 11:39PM |
