Shift problem using XT
Posted by chriske
March 11, 2017 05:57AM
Hi guys,
This is a weird one...
Same printer, same settings.
Differences : Material PLA printed at 215/60. The other material is XT printed at 260/75
Using PLA there is no problem at all, prints up to 9 hours. Beautiful prints, very nice and flat perimeter with no issues(ripples) at all. Every time again.
Using XT : Prints nice to but suddenly shifting in Z direction every time again. No particular distance, shifting is never the same amount. It jumps from 1 to about 6 mm.
Several tests first PLA then XT, every time again, same result.
It's obvious it has nothing to do with the material itself. It is temperature related, but what is the problem...?
Printer: i3 - 200x300 / Marlin / Prusa-Slicer / Direct drive 1.75mm
Chris
Re: Shift problem using XT
March 12, 2017 09:12AM
Meanwhile already change 10 times filament.
Meaning alternately same object printed 5 times with PLA and 5 times using XT.
Every single time bed-shifting when printing with XT filament. NO problem with PLA at all.
March 12, 2017 10:44PM
"shifting in Z direction" thats very odd
Are you sure you have your axis right?
left/right is X axis
front/back is Y axis
up/down is Z axis
If it is Z, what sort of drive mechanism does you machine have on Z? most this would be a drive screw of some sort.
Edited 1 time(s). Last edit at 03/12/2017 10:45PM by Dust.
March 13, 2017 07:14PM
Oops...!
That should have been Y instead of Z of course....confused smiley
The second post I mentioned bedshifting, it should have been clear I made a mistake.
Sooorryyy...
