Print bends up under the nozzle
March 20, 2017 07:25AM
I have a problem printing small areas that get bigger in z direction. The PLA bends up under the nozzle which builds up a "wall" of PLA that is higher than the nozzle height.
This results in a bad print. Also in worst case the wall gets so big that the nozzle collides with it causing lost steps in x or y direction and shifting the print.
I dont know what causes this.
I have no problem with first layer adhesion, so no warping. I have a Prusa Hephestos with a Diamond Hotend. Maybe someone can help.
Thanks!
open | download - Unbenannt.PNG (419.9 KB)
Re: Print bends up under the nozzle
March 20, 2017 09:18AM
It sounds like your cooling isn't adequate enough. You might want to look into a better part cooling system.
March 20, 2017 02:55PM
Thanks! I had auto cooling enabled in slic3r. Now I have it at 100% and it works.
