Problems with printer hot bed not being consistent May 06, 2017 07:51AM |
Re: I prusia printer Sintron, Mk8 ramps 1.4 marlin quits 30% in May 06, 2017 08:18PM |
Re: Problems with printer hot bed not being consistent May 07, 2017 03:17AM |
Re: Problems with printer hot bed not being consistent May 07, 2017 10:22AM |
Re: Problems with printer hot bed not being consistent May 07, 2017 05:01PM |
Re: Problems with printer hot bed not being consistent May 07, 2017 05:22PM |
Re: Problems with printer hot bed not being consistent May 08, 2017 10:02AM |
Re: Problems with printer hot bed not being consistent May 08, 2017 02:09PM |
Re: Problems with printer hot bed not being consistent May 09, 2017 05:03AM |
Re: Problems with printer hot bed not being consistent May 15, 2017 05:34PM |
New bed installed and still same issues with the heating. May 15, 2017 07:17PM |
Re: Problems with printer hot bed not being consistent May 16, 2017 03:44AM |
Re: Problems with printer hot bed not being consistent May 16, 2017 08:46AM |
Re: Problems with printer hot bed not being consistent May 16, 2017 08:54AM |
Re: Problems with printer hot bed not being consistent May 17, 2017 09:02AM |
Re: Problems with printer hot bed not being consistent May 17, 2017 11:29AM |
Inhumierer
3.8 Ohm is a reasonable value for the bed, this seems to be good. These nasty polyfuses do behave very strange sometimes, but it doesn't sound like a polyfuse problem. Is your bed loosing the voltage and stops heating, or is your RAMPS shutting down the heater for any reason?
In your test print logfiles from May 7 I can see the bed temp is set to 70 deg, then reaches 69.something, and then drops again for no reason I can see. On the RAMPS board, there is a LED to show if the heatbed is on or off. Do you use a PID regulation for the bed, or just bang bang? Does the LED start to flicker or go off when the temperature drops? Can you put your multimeter in parallel to the bed when heating up? DCV 20 will be the right position to check the voltage of 12V. If the LED is on, your multimeter should display something close to 12V. If you use PID, and the LED is flickering, your multimeter can't keep up, so no worries.
Re: Problems with printer hot bed not being consistent May 17, 2017 05:50PM |
Re: Problems with printer hot bed not being consistent May 18, 2017 04:09AM |
