Problem with a printer
May 26, 2017 02:14PM
Hello!
Anybody could you add me advice how to fix this problem?
[drive.google.com]
Re: Problem with a printer
May 26, 2017 04:54PM
Is that whole extruder moving?!
Also looks like you havent calibrated the Z home switch either. Your print start height is WAY off.
Have you calibrated the extruder also?
Looks like you tossed some parts together and hoped it would work. Take some time and get everything calibrated.
May 26, 2017 05:59PM
Follow this guide, will get you printing (Link: [reprap.org]) Dont skip any steps, ask questions if needed
May 27, 2017 04:09PM
I ordered that [www.ebay.com]
And that was too long and I applied it higher...Could you post there a video how to calibrate that?
May 27, 2017 04:10PM
There is a video for that?Because my english is really bad
June 03, 2017 08:55PM
As Floyd says, you need to set up your Z-Axis home switch first which will determine the height between your hot end nozzle and the print bed.
Then you need to ensure that the print bed is level, i.e. the nozzle to print bed distance should be constant at all positions around the print bed.
The distance is equivalent to the thickness of a sheet of paper, approx 0.1mm.
The best place to find videos to help you with problems is probably YouTube, check out this nozzle height and leveling video which covers quite a lot of different printers.
Play Bonny!
Soadyheid
June 07, 2017 08:11AM
Show video of Start print process so I can See.
Also you need a surface for the Filament to stick to.
I use a form of Vinyl Transfer Tape that is Paper Backed see photo.
Edited 5 time(s). Last edit at 06/07/2017 08:37AM by Roberts_Clif.
