Question about what I need to provide before I ask my question June 01, 2017 11:27AM |
Re: Question about what I need to provide before I ask my question June 01, 2017 03:49PM |
Re: Question about what I need to provide before I ask my question June 01, 2017 06:10PM |
. (a) It's not a question. (b) No-one here could possibly know how good your friend's printer is. I'm not going to get into a long-winded discussion where you (or your friend even) tells me "It's quite a good printer really, although he hasn't used it for 3 years" and then somehow assess his printing skills. *You* are in a much better position than me to make those kinds of judgments.Quote
A friend of mine said he'd print the parts at cost but I want to make sure he can do it. I figure if his printer can do it might reduce some of the costs.
Re: Question about what I need to provide before I ask my question June 01, 2017 09:18PM |
Re: Question about what I need to provide before I ask my question June 05, 2017 12:24PM |
chris33
if your printing pla the fan is a defo what speed are you printing? what type of extruder have you got? what temps are you printing at? start with the extruder is it been calibrated?
Re: Question about what I need to provide before I ask my question June 05, 2017 12:30PM |
frankvdh
I agree that your part looks to be under-extruded. Why are you extruding at 85-90% and not at 100%? The only time I would do that would be if I measured the filament and found it to be *much* too fat. If the measured filament is 1.72mm, the correct factor would be (1.75*1.75)/(1.72*1.72) = 103%
Re: Question about what I need to provide before I ask my question June 05, 2017 07:21PM |
Volume extruded is cross-sectional area * height. The cross-sectional area of filament is (assuming it's circular) is PI*r^2. Cross-sectional area of 1.72mm filament = Pi*1.72/2*1.72/2 Cross-sectional area of ideal 1.75mm filament = Pi*1.75/2*1.75/2 So, if you want to extrude the equivalent of 100 "steps" of 1.75mm filament, but you only have 1.72mm filament, you need to extrude (Pi/4*1.75*1.75)/(Pi/4*1.72*1.72) *100 = [Pi/4 cancels out] (1.75*1.75)/(1.72*1.72) * 100 = 103 steps. The "flow rate" is exactly that; the correction factor from your actual filament to the ideal 1.75mm filament diameter, expressed as a percentage.Quote
The3rdIcon
frankvdh
Can you explain where this math comes from? I'm not familiar with 3d printer more so designing for the printer itself.
Also thanks for the help with how to narrow my post someone is likely to answer my question. As far as searching the forums here and elsewhere, Do you have a recommendation of what to use if the internal search stinks and the site doesn't allow google to index them so I can't use the qualifier of "site" in the search?
Another issue I've run into is I can't figure out how to narrow down the description of my issue for search purposes. i.e. after searching and reading I feel like I'm getting to many results not related to the question I'm trying to get answered.
Re: Question about what I need to provide before I ask my question June 06, 2017 10:05AM |
