Unlevel Print Bed with working Auto Leveling
Posted by Swulf1
June 05, 2017 04:35PM
So I am sure there is someone out in the community that has seen this before, and I wanted to reach out to get some insight. I did do some searching on the forums, but I was not able to find exactly what I was looking for. I have auto bed leveling on, and I know it works (the z-axis motors move constantly to adjust for the measured bed height deltas). However, I am still seeing quite a bit of variation in the height of the bed and the thickness of the printed filament. Are there any other answer besides 'lower the height of the bed on the front right'? Why would the autoleveling function not account for this? Thanks.
open | download - Uneven_Bed_Print.jpg (463.3 KB)
Re: Unlevel Print Bed with working Auto Leveling
August 08, 2017 07:36AM
Hey,
I know you posted this a while ago. Have you found a solution yet? If not, what kind of leveling algorithm are you using? Is it possible that you have a dent in your bed at the point the probe is checking to determine the front right corner? I believe you can increase the number of probe points for autolevel, this might help to figure out if there is a dent.
Cheers...
