Filament Stripping!!! June 08, 2017 04:36AM |
Re: Filament Stripping!!! June 08, 2017 06:23AM |
Re: Filament Stripping!!! June 08, 2017 07:07AM |
Re: Filament Stripping!!! June 08, 2017 08:19AM |
Re: Filament Stripping!!! June 08, 2017 08:30PM |
the_digital_dentist
Filament stripping, is caused by only one thing. There is a bearing that presses the filament against the drive gear, usually spring loaded. If the pressure is too low, the gear doesn't bite deeply into the filament and will strip it. Increase the pressure. It should almost crush the filament. The motor should start skipping steps before the filament strips.
Re: Filament Stripping!!! June 08, 2017 09:00PM |
Re: Filament Stripping!!! June 09, 2017 04:26AM |
