Brand new hot end, same problems
Posted by rich1051414
June 14, 2017 11:55AM
I have had a reoccurring issue that has plagued me ever since I got into 3d printing, and I really do not know what it is. Eventually, my printer will start stripping filament halfway through a print, but I cannot figure out why. It even did it on the first print of a brand new authentic e3d v6 hotend. I have eliminated all possible culprits except for one, the feeder assembly. It uses a grooved bearing and a 40 tooth feeder gear, and I am starting to this this setup is causing my problems.
Here is a macro shot of the stripped filament removed after the failed print:
Edited 1 time(s). Last edit at 06/14/2017 12:08PM by rich1051414.
open | download - IMG_20170614_110105.jpg (608.6 KB)
Re: Brand new hot end, same problems
June 14, 2017 12:21PM
The extruder moves the filament by having the teeth of the drive gear bite into the filament. If the teeth don't bite deeply, and there is some resistance to moving the filament in the hot-end, the teeth of the drive gear scrape the surface of the filament and chew a divot into it. If the teeth bite deeply, they don't scrape the surface of the filament, they just push it. If the resistance to motion is too great, due a physically blocked nozzle, for example, the extruder motor will start to skip. The depth of bite is controlled by the pinch roller that presses the filament against the drive gear. If the extruder is chewing divots into the filament, the solution is to increase the pressure on the pinch roller. It should be very high, almost to the point of crushing the filament. You want to ensure that the motor skips without chewing up the filament.
Why the filament resists the extruder's push is a completely different matter. If there is some heat creep or excessively long retraction, things may get sticky inside the throat or heat-break of the hot end. For direct extruders, retraction of 1-2 mm is usually sufficient. More than that risks pulling soft filament up into the heat-break.
True nozzle blockages are pretty rare. Most of the extruder jams people complain about occur because they leave the pinch roller pressure too light so the extruder chews a divot into the filament. If you still have jams after you fix the pinch roller pressure problem, maybe the motor has insufficient torque to push the soft filament back down the tube. Geared extruders suffer many fewer jams that ungeared extruders because the gears multiply the torque available to push the filament.
June 14, 2017 02:50PM
I provided a picture showing the teeth of the gear is biting into the filament. Also, it is a brand new extruder, so its not jamming. I will check my retraction to see if that is a problem, but as far as the pinch roller pressure, I think that is sufficient given how much the gear is biting into the filament.
June 14, 2017 03:15PM
Brand new extruders can jam, for any number of reasons (temperature, nozzle height). The jam may also be elsewhere... spool holder?
The extruder tension should be high enough that the motor skips before the filament strips.
June 14, 2017 03:42PM
It doesn't look like the teeth are biting deeply into the filament at all. Maybe the teeth aren't sharp, or maybe you don't have the pinch roller pressure turned up enough, or both.
June 15, 2017 11:32AM
Can you provide a picture of the machine?
This looks like a Bowden system but the tube seems short.
Im assuming the RHS of the picture is the hot end which shows about 8mm of melted filament so as DD says check you retraction.
If this is the length of the tube it may be too short or not have enough bend to allow for good flow at certain positions.
June 16, 2017 07:11AM
It is a direct feed, but it feeds into a E3d V6, which has a pretty long heatsink. There is also a 10mm gap between the bottom of the extruder stepper and the top of the hotend.
Regardless, reducing the retraction distance from 10mm to 2mm has alleviated the problem. I think the issue was the retraction was too far and strings were flash cooling then clogging things up.
Edited 1 time(s). Last edit at 06/16/2017 07:12AM by rich1051414.
June 16, 2017 10:16AM
Wow! 10 mm is definitely too much for a direct extruder. Even with excessive retraction length, it should not have been chewing divots into the filament.
June 17, 2017 05:55AM
10mm?
Crikey!
The extruder was almost certainly unable to keep up. Where on earth did you get that setting from?
_______________________________________
Waitaki 3D Printer
June 17, 2017 02:52PM
waitaki
10mm?
Crikey!
That is the default in Cura, I certainly didn't set that!
July 13, 2017 05:30PM
Get a better extruder wheel. The one you have has large teeth spacing which does not feed smoothly especially with Nema 17 direct drive extruders.
Edited 1 time(s). Last edit at 07/13/2017 05:31PM by newbob.
September 02, 2017 12:36PM
I was having issues with heat creep on my printer that was in the garage. My filament would bubble at the top of the cold end and then swage and my extruder would grind the filament and my print would just die. I put on a watercooled cool end and all my problem went away
Here is a vid
[www.youtube.com]
Thanks
Eric
