Periodic patterns on outer shell
Posted by trgtylcnky
June 21, 2017 09:32AM
Hi, I am getting some periodic patterns on mu outer shell. I think it is about extrusion because its phase changes although period doesn't by layers. It is like over-extruding every X millimeter of filament. Here is a picture:
Any ideas?
Edited 1 time(s). Last edit at 06/21/2017 09:33AM by trgtylcnky.
Re: Periodic patterns on outer shell
June 21, 2017 10:17AM
Ungeared extruders do that, even with 16:1 ustepping. You can play with the extruder current to tweak the way it looks, but it won't go away completely unless you use a geared extruder which increases the "resolution" of the extrusion process.
You may have a bit of over-extrusion going on, too.
Edited 1 time(s). Last edit at 06/21/2017 10:17AM by the_digital_dentist.
June 22, 2017 01:38PM
I only have direct drive extruders on my printers and have never seen a pattern like that.
Are you sure your drive gear is clean and "round"? I've had chinese drive gears that weren't cut evenly. As a result the filament slipped a bit on every turn.
June 26, 2017 04:41PM
I have the same problem also. I tried changing;
  • the Smoothie board with new one (new drivers)
  • Extruder motor
  • Dampers on X and Y motors
  • the Smoothie stepping from 1/32 to 1/16
  • printing speed (low speed)
However, the problem is continues!
Edited 2 time(s). Last edit at 06/27/2017 06:15AM by cagtag.
