X axis hitting "wall"
August 05, 2017 12:29PM
I can't seem to find the issue that is causing this. When i print, and the object spans the entire width of the bed, the right (my right) end of the print seems to hit this invisible wall where all the printing bunches up as if the printer doesn't think it can go that far and just prints everything that is past that x coordinate the the same y plane. I can add pictures if you need a better explanation. Does anyone have any ideas for this?
Re: X axis hitting "wall"
August 05, 2017 01:43PM
Sometimes pictures help, Thou in this case more information is required.
Is kind of sounds like between your slicing software and your 3D Printer the borders are different. Example you have a 220x270 bed that is defines as a 270x220 bed.
OR
Your configuration is off and the printer thinks it is at max on that axis.
Yes it would be help-full to have more information.
Is this factory firmware or did you setup firmware yourself, What firmware, What slicer software ect.
Can you manually maneuver the around the entire print area without being stopped at this location.
Edited 1 time(s). Last edit at 08/05/2017 01:49PM by Roberts_Clif.
August 06, 2017 09:44PM
it was mistyped bed dimensions in the firmware. i figured it out. thanks.
