ABS printing problem
August 30, 2017 10:12AM
I have a marlin based 3d printer.
My printer use the coreXY system.
I tried to print this model using ABS and i have this problem:
- The first layers are ok but in middle the print are deformed.
I'm using this temperature configuration:
- BED 110°
- NOZZLE 225°
- FAN OFF
Any ideas?
Thanks
Edited 1 time(s). Last edit at 08/30/2017 10:17AM by DapDeveloper.
open | download - IMG_20170830_155836.jpg (62.4 KB)
Re: ABS printing problem
August 30, 2017 10:42AM
Maybe overextruding?
Have you calibrated your extruder?
August 30, 2017 10:50AM
Yes, i have calibrated my extruder.
The problem is that i have printed 4 of this model and are equal.
August 30, 2017 10:54AM
Maybe this picture explains better the problem.
open | download - IMG_20170830_165109.jpg (57.1 KB)
August 30, 2017 11:10AM
Photos of printer may help. What extruder and hot-end? Which slicer? Slicer settings?
August 30, 2017 11:24AM
I have a 0.5 nozzle and I'm using simplify3d slicer
August 30, 2017 02:07PM
How big is that part?
Are you printing just one at a time?
That second picture from the top almost looks like underextrusion but its hard to tell with the glare and all.
ABS likes to go slower and have loads of time to solidify. I print mostly all ABS and I print at no faster than 40mm/sec and print at about 240c
September 08, 2017 03:52AM
Does the problem start when the part in the center is done? Try to print slower.
September 12, 2017 01:56AM
my opinion is that you have two problems. first the nozzle is not too tied and the second and most important is that ur design is wrong. At that point you are getting too much material. So the nozzle doesn't move on air or above the previous layer but "inside" it. At that point if you look carefull you ll see that the nozzle is touching ur print with enough force. You have to lower the amount of abs or/and the infill and/or you have to specify height and then width of the extrusion.
but pictures and more details at mentioned above would be very helpfull.
Delta Printer
Duet 0.8.5 firmware 1.19
September 27, 2017 01:28PM
Try reducing the flow rate to 80%. If it improves, then take it a little lower to 75%, and see if it get better, or stays the same.
Temperature might also be an issue. I would say it is a little too cold, but I don't have enough information to make a better educated guess.
October 16, 2017 05:07PM
My bet is thats a draft issue, its good close to the bed because its warmer there....
do you have a hood or cover for your printer?
close in the printer so the air around the print is kept warm and no drafts, boost your extrude temp a little say 245c
A hood for ABS printing is a must.... Or a really really hot room!!! smiling smiley
check and see if your fan comes on at those layers....
I doubt your over extruding, or it would show at the lower levels too...
Edited 2 time(s). Last edit at 10/16/2017 05:11PM by JustSumGuy.
