Dual extruder - one filament
Posted by Arnold
October 20, 2017 04:26PM
Hi all,
have question about dual extruder.
I have Cyclops type of extruder.
I have two ways in and one nozzle. There are two ways in heating block, one from
left side and second from right side. If I print two colors I understand
that color changing is through purge block but what happen when
I want to print only one color ? For example I am going to print with ABS 8 hours,
what will happen with opposite chamber on right side which is also heated and there is also some
rest of filament heating up ? Will it clogg through the time when its heated and not used ?
I still use V6 but want to switch to Cyclops, so that is why I ask.
Re: Dual extruder - one filament
October 23, 2017 10:11AM
Arnold
most likely: yes
October 24, 2017 04:38AM
Ok, thanks, I will try chimera settings then.
October 25, 2017 06:27PM
Why not just do a cold pull to get the filament out of the side you won't be using?
