threaded rod question +software November 30, 2017 01:49PM |
Re: threaded rod question +software November 30, 2017 05:33PM |
Re: threaded rod question +software November 30, 2017 06:15PM |
Re: threaded rod question +software December 01, 2017 03:13AM |
Re: threaded rod question +software December 01, 2017 09:16AM |
Re: threaded rod question +software December 01, 2017 09:45AM |
Re: threaded rod question +software December 01, 2017 01:41PM |
Re: threaded rod question +software December 04, 2017 10:03AM |
Re: threaded rod question +software December 04, 2017 07:22PM |
Re: threaded rod question +software December 05, 2017 06:05AM |
Re: threaded rod question +software December 05, 2017 11:29AM |
obewan
If you mean a part cooling fan, this is usually connected to the 2nd extruder heater output(if your board has one). and is controlled via the slicer software
Re: threaded rod question +software December 05, 2017 12:18PM |
Re: threaded rod question +software December 05, 2017 12:49PM |
Re: threaded rod question +software December 06, 2017 11:11AM |
Re: threaded rod question +software December 06, 2017 11:31AM |
printjunkie
These are the lead screws that I bought. Is the pitch the "lead of thread" or the "screw spacing"?
Specification:
Brand new
Material: stainless steel lead screw, copper nut
Screw diameter: approx. 8mm
Length: approx. 100mm/ 150mm/ 200mm/ 250mm /300mm /350mm/ 400mm /500mm/ 600mm
Screw spacing: approx. 2mm
Lead of thread: approx. 8mm
Range: 3D printer accessories, stepper motor
There are 100mm/ 150mm/ 200mm/ 250mm /300mm /350mm/ 400mm /500mm/ 600mm, there have same lead of thread(8mm) which is the distance of the nut to rotate a circle
Suitable for: industrial automation equipment, stepper motor rails; such as 3D printers; engraving machine; XYZ module; slider; lifts, etc
How do I find out what my driver microstepping is?
I would be fairly certain that the pitch is 2mm and the diameter is 8mm from that.
Re: threaded rod question +software December 08, 2017 12:01PM |
Re: threaded rod question +software December 09, 2017 05:47AM |
Re: threaded rod question +software December 09, 2017 08:27AM |
Re: threaded rod question +software December 09, 2017 05:33PM |
the firmware is in marlin. I read the comments about sending g code from repeiter host but am not sure when to send it. (By itself, during a print, ect.)|
Re: threaded rod question +software December 09, 2017 08:01PM |
Re: threaded rod question +software December 10, 2017 12:32PM |
Re: threaded rod question +software December 10, 2017 08:21PM |
Re: threaded rod question +software December 11, 2017 05:45AM |
Re: threaded rod question +software December 11, 2017 05:10PM |
Re: threaded rod question +software December 12, 2017 09:54AM |
Thanks for all the help!
Re: threaded rod question +software December 12, 2017 11:12AM |
printjunkie
I must say the lead screws were the best 15 bucks I have spent in a long time. Coupled with the cooling fan-woah!!!! The quality is incredible! The M500 gcode worked. I only have one more problem to fix. My cooling fans(both the 2 pin and the 3pin) get power and push air. I can't change the speed. The fan is plugged into the fan3 port on the board and runs no matter if the fan icon on rep is on or off. Both the 2 pin and the 3 pin fans (I only have one plugged in at a time; the other is a spare) don't change speed when I tell them to. So, other than that, I am over the moon with my printer. I am officially back into the love part in our love/hate relationshipThanks for all the help!
Re: threaded rod question +software December 12, 2017 08:34PM |
Re: threaded rod question +software December 13, 2017 02:03PM |
Re: threaded rod question +software December 15, 2017 11:41AM |
Re: threaded rod question +software December 17, 2017 04:18AM |
