Prints coming out terrible!!
Posted by usajet
December 12, 2017 07:47AM
Any suggestions on what I should do? I have the right size of filament in the slicer.
Thank you Nathan
open | download - IMG_0079.JPG (560.9 KB)
open | download - IMG_0080.JPG (347.4 KB)
open | download - IMG_0082.JPG (555.8 KB)
open | download - IMG_0083.JPG (603.5 KB)
Re: Prints coming out terrible!!
December 12, 2017 08:59AM
Could you give more information, Speed models printed at, Temperature models printed at, Material Printed with.
Do you have a parts cooling fan, What speed is parts cooling fan set to.
December 12, 2017 09:27AM
I am not at home right now so I will do my best.
printing speed 60mm/s with PLA at 205 degree C. I have a parts cooling at 35%.
December 12, 2017 09:54AM
That looks like a lot of underextrusion. Are you sure the steps/mm for the extruder and the filament diameter are set correctly?
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
December 12, 2017 11:51AM
Filament is set to 1.75 mm. What should the steps/mm be set at?
December 12, 2017 01:39PM
This would depend on what kind of extruder setup you have.
December 13, 2017 03:59AM
1.75mm is the general diameter, but not neccesarily the actual diameter. You need to measure with calipers and calculate the factor to make up for slightly larger or smaller diameters.
The E Steps value is usualy set correctly in the firmware if you buy a complete printer. If you build it yourself or changed the extruder you need to calculate, and measure for control, how many steps it takes to push the filament 1mm. I usually calculate the intial value from the circumfenernce of the filament pulley and then measure over 1m of filament for fine tuning.
[www.bonkers.de]
[merlin-hotend.de]
December 13, 2017 07:33AM
How would I calculate it? Is there a calculator to use? Thank You!
Edited 1 time(s). Last edit at 12/13/2017 07:37AM by usajet.
December 13, 2017 09:05AM
[reprap.org]
For the extruder start at step 4
P3steel DXL, with Due/RADDS/Raps128 dual Wade's extruder
December 13, 2017 02:09PM
December 14, 2017 03:22PM
It ended up being a clogged nozzle. Thank you for all your help.
December 14, 2017 07:12PM
Clogged Nozzles and Deformed PTFE throat liners are real common problems of under-extrusion. I have many nozzles and PTFE Lined throats in the parts bin.
This is why I ask for more information. When we see new users or users with few forum posts we assume.
With more information we could have seen that you had successfully 3D Printed, and could have given the other reasons why your nozzle could be under extruding.
Need more help, just post question?
Edited 1 time(s). Last edit at 12/14/2017 07:13PM by Roberts_Clif.
