Low Steps Per mm - Cause, effect, solution?
Posted by kdsonone
January 10, 2018 05:11PM
Hello All,
I am building my own 3D Printer - Graber i3. I have followed all the necessary steps to configure the Marline firmware.
I am using the Ramps 1.4 controller board and the A4988 driver. The stepper motor I am using for X, Y and Z axis has 1.8-degree step angle.
I have used the Pursa Calculator to calculate the steps for X, Y, and Z axis - 80, 80, 1600 based on the GT2 pully-belt and 2mm threaded rod - screw system.
ISSUE:
* When I am using the calculated steps for the X, Y and Z axis I am observing higher movement (i.e 10-15 mm when I want to move 1mm)
* I have calibrated the movement by reducing down the calculated steps -
now the new steps are X=6.5, Y= 6.5 and Z = 26.66
1. My question is why I am getting such a lower steps per axis?
2. How can I get more accurate movement without skipping/slipping of the motor?
Please help
Thank you
Kunal
Re: Low Steps Per mm - Cause, effect, solution?
January 10, 2018 05:55PM
It sounds as though you don't have the microstepping jumpers fitted underneath the drivers.
January 16, 2018 01:11PM
GT2 timing belt and pulleys should give you values near the 90 steps/mm point with motors that are 200 steps/revolution, and 16X microstepping.
As stated above, check that there are jumpers under the stepper motor drivers on your RAMPS board. Under each A4988 there will be a group of 3 jumpers. If they are all closed (Jumpers present) then you should have 16X microstepping, which will give you the kind of resolution that you're looking for.
