Print moves mid print when printing large objects February 16, 2018 02:34PM |
Re: Print moves mid print when printing large objects February 17, 2018 02:54AM |
Re: Print moves mid print when printing large objects February 17, 2018 04:51AM |
o_lampe
There are many reasons for "skipped steps" which is the term you should start searching with.
Two reasons, which are the most popular:
Stepper current to low => adjust Vref
Over-Extrusion causes the nozzle to bump into the print => calibrate e-steps
Re: Print moves mid print when printing large objects February 22, 2018 06:06PM |
Re: Print moves mid print when printing large objects February 23, 2018 07:23AM |
Re: Print moves mid print when printing large objects February 23, 2018 03:11PM |
Re: Print moves mid print when printing large objects February 23, 2018 03:38PM |
Re: Print moves mid print when printing large objects February 23, 2018 07:07PM |
nukes88
My printer is a i3 style and not in an enclosure could that be the problem it prints pla fine
Re: Print moves mid print when printing large objects February 24, 2018 03:14AM |
Re: Print moves mid print when printing large objects February 25, 2018 02:13PM |
o_lampe
I made my own liitle enclosure by printing a 2 perimeters thick skirt around the part. The skirt requires a very good print surface, like the ( fake? ) PEI sheet I tested. I can't guarantee, bigger ABS parts won't crack, but the temp inside the skirt was high enough; I had to use 30% part-cooling to keep the part from softening.
[attachment 102873 2018-02-1710.27.36.jpg][attachment 102874 2018-02-1710.27.51.jpg]
