Layer Shift of some Layers, Print recovers after the Shift
Posted by 3iswolf
April 12, 2018 10:15AM
Hello,
i am ne to this forum. I need some help with my self build Printer. I am running Marlin 1.1.8 on RAMPS 1.4. For the Axes i use some big Driver (DQ542MA). It is a huge Printer (940*650*310 mm) For the Extruder i use a E3D Vulcano.
For now i am not trying to print big, but to get the Printer to his best precision with a 0.6 mm Nozzle. Testing the Axes, max Speed and so on.
I attached my Marlin configuration. I use Bilinear BL otherwise where is nothing special. Fade Height is 0.2mm
I have a issue in my Print there i really don't know there to look at to solve it.
After some Layers printing normal. The printer shifts the x-axis for a various count of layers. But after that it prints normally and at the right position. I made some pictures of the issue.
I tried different Slicers. Different Objects. Different Speed, Accelerations and Jerks.
What can cause a issue like that?
Also i have some issues with ABL but this ist more interesting with big Prints.
Edited 1 time(s). Last edit at 04/12/2018 10:17AM by 3iswolf.
open | download - Configuration.h (65.2 KB)
open | download - Configuration_adv.h (63.5 KB)
open | download - 30232020_1684671814903534_745185228_o.jpg (175.7 KB)
open | download - 30177189_1684671831570199_1534748989_o.jpg (162.1 KB)
Re: Layer Shift of some Layers, Print recovers after the Shift
April 12, 2018 10:21AM
A little shift like that is often a loose pulley on the stepper
In particular a stepper with a flat on the shaft, with the grub screw loose it can move 90 odd degrees without rotating.
Draw a line on your stepper and pulley, make sure it not moving (line will break)
