Can't get proper dimensional accuracy. April 20, 2018 10:51PM |
Re: Can't get proper dimensional accuracy. April 20, 2018 11:33PM |
Admin Registered: 13 years ago Posts: 7,000 |
Re: Can't get proper dimensional accuracy. April 21, 2018 12:25AM |
Dust
3d printers cannot print accurate holes... You have to over size them in the CAD.
See [gilesbathgate.com] as to why and the math needed to correct for it.
Re: Can't get proper dimensional accuracy. April 21, 2018 01:38AM |
Re: Can't get proper dimensional accuracy. April 21, 2018 08:36AM |
Re: Can't get proper dimensional accuracy. April 21, 2018 01:19PM |
Dust
Your picture is of a stepper motor and the plastics is barely part of the picture!!
You haven't included your models.. so we have no idea is its design error or what
Even just the stl would help...
But basically your saying that machine is not calibrated.
So what firmware is it running, did they provide source so it can be edited?
Re: Can't get proper dimensional accuracy. April 21, 2018 01:39PM |
the_digital_dentist
I don't know how to fix the problem with your printer, but I can tell you that that motor mount is going to be completely unsatisfactory if the motor is moving any kind of load. That type of design is the first thing that comes to mind because you see them made of steel. The problem is we're not using steel. Plastic is flexible. Another thing to consider: that's a large motor and will probably operate with a lot of current and generate a lot of heat. The motor mount will soften. The combo of heat and load will distort it beyond recognition.
If I were trying to mount a motor like that using a printed plastic mount, I'd design it like a block that covers the shaft, then remove just enough material for the shaft and pulley or coupler or whatever is going to attach to the shaft, and then add some screw holes to mount it. Sort of like this NEMA-17 example:
[attachment 104483 motormountdesignideav2.png]
Re: Can't get proper dimensional accuracy. April 21, 2018 06:54PM |
Re: Can't get proper dimensional accuracy. April 22, 2018 04:34AM |
Alex_1234
I have had a Anycubic Kossel delta printer for about 6 months now and have recently been printing parts that need accurate parts. The first thing I noticed the problem with was a NEMA 23 that I modeled with ~1mm larger clearances that was printer at 105% scale and still was too small for the motor to fit. I tried different extrusion multipliers, nozzle sizes, line widths, and delta rod length but parts still come out 0.5mm too big on the outside and 0.5mm to small in holes. I have tried everything I can think of and looked online but nothing has worked.
If anyone has any advice in would be greatly appreciated.
Re: Can't get proper dimensional accuracy. April 22, 2018 10:08AM |
Re: Can't get proper dimensional accuracy. March 29, 2019 11:46AM |
Re: Can't get proper dimensional accuracy. April 01, 2019 04:46PM |
Mikejn1
I realize this post has a bit of age to it, but I am experiencing the same issue.. The Z-height is spot on but X and Y are a little larger than they should be, dimension wise.. The post above said to adjust the DELTA_DIAGONAL_ROD in the firmware.. I have an Anycubic Kossel with Marlin firmware 1.1.0... Where do I find these settings?
I am a beginner when it comes to 3D printers but I am willing to learn..
Thank you
