Successful 1st ABS Print September 14, 2018 10:16PM |
Re: Successful 1st ABS Print September 16, 2018 07:49AM |
Re: Successful 1st ABS Print September 16, 2018 07:51AM |
Re: Successful 1st ABS Print September 20, 2018 05:41AM |
Re: Successful 1st ABS Print September 20, 2018 09:13AM |
Srek
The fan will be a problem with most prints, cooling ABS during printing is not necessary and often problematic. It behaves very differently than PLA. For bigger parts try to prevent draught, depending on the shape of your printer try to enclose it. Often enough covering it with a mylar foil can improve prints hugely.
Re: Successful 1st ABS Print September 25, 2018 01:07PM |
Roberts_Clif
Srek
I understand though my printer is inside a heated chamber so in fact am blowing the chambers heated air on to the Part, would this make a difference.
However the chamber air temperature is around 40C. The above Fossil Fish I printed was one of the Better models I have printed though not the Best.
The bridging was almost perfect as it was removed with very little pressure what so ever and the hinges functioned the second the part was removed.
Re: Successful 1st ABS Print September 28, 2018 03:02PM |
Re: Successful 1st ABS Print September 29, 2018 12:02PM |
Re: Successful 1st ABS Print October 01, 2018 02:43PM |
Re: Successful 1st ABS Print October 01, 2018 03:10PM |
Re: Successful 1st ABS Print October 01, 2018 04:54PM |
Re: Successful 1st ABS Print October 01, 2018 07:34PM |
