Filament change script help please November 16, 2018 09:40PM |
Re: Filament change script help please November 17, 2018 02:54AM |
Re: Filament change script help please November 17, 2018 11:05AM |
Re: Filament change script help please November 17, 2018 06:15PM |
Dunston-UK
So it would look like ?
{REPLACE "\n; layer 7," "\n;***PAUSE***\nM266,}
I not sure what the remaining line would look like. I will try it out. Thank you DC42.
Re: Filament change script help please November 17, 2018 06:57PM |
dc42
Dunston-UK
Yes, except it's M226 not M266. The forthcoming 2.02RC4 firmware release allows you to use M600 instead, which works in exactly the same way except that you can choose to run a different pause macro, for example one that unloads the filament and prompts you to load new filament.
Re: Filament change script help please November 18, 2018 06:42PM |
Dunston-UK
dc42
Dunston-UK
Yes, except it's M226 not M266. The forthcoming 2.02RC4 firmware release allows you to use M600 instead, which works in exactly the same way except that you can choose to run a different pause macro, for example, one that unloads the filament and prompts you to load new filament.
Now that exactly what I’m looking for. That will make it a whole lot easier to use I hope. When is 2.02rc4 due?
Re: Filament change script help please November 19, 2018 02:51AM |
Re: Filament change script help please November 19, 2018 03:23AM |
dc42
Yes that's correct, also set up the /sys/filament-change.g file on the SD card to do whatever you want, otherwise it will run the usual pause.g file.
Re: Filament change script help please November 19, 2018 03:51AM |
Re: Filament change script help please November 21, 2018 08:45AM |
dc42
You don't need to include a pause in that file, just do the same sorts of things that you do in the pause.g file, followed by any additional commands you want such as unloading the old filament.
Re: Filament change script help please November 21, 2018 01:50PM |
Re: Filament change script help please November 21, 2018 02:01PM |
Re: Filament change script help please November 21, 2018 02:28PM |
Re: Filament change script help please November 22, 2018 05:17AM |
