weird problem with under-extrusion only on first layers after the first one.. Any ideas? December 07, 2018 01:24PM |
Re: weird problem with under-extrusion only on first layers after the first one.. Any ideas? December 07, 2018 02:47PM |
Re: weird problem with under-extrusion only on first layers after the first one.. Any ideas? December 07, 2018 03:52PM |
Re: weird problem with under-extrusion only on first layers after the first one.. Any ideas? January 08, 2019 07:20PM |
PDBeal
I've experienced some issues with 0.6 nozzles compared to 0.4 nozzles and it seems to miss some sections and creates gaps. I'm still working to figure out the exact cause, but I suspect neither Slic3r or Cura work well with anything beyond 0.4 nozzles. It's almost like the tooling paths are setup and designed for 0.4, and just increasing the nozzle size causes some "errors" to happen around certain features. In my case I could see a direct issue between 0.4 nozzles and 0.6, as a print would be perfect at 0.4, but re-sliced at 0.6 would result in some gaps around certain features. I'm still testing, but I plan to see what a 0.8 nozzle does and with it being a multiple of 0.4 if its better than a 0.6.
I did have some success on certain parts setting my extrusion width or nozzle size to 0.58 instead of 0.6 and that did seem to correct some of those gap issues.
Re: weird problem with under-extrusion only on first layers after the first one.. Any ideas? January 09, 2019 08:16AM |
Re: weird problem with under-extrusion only on first layers after the first one.. Any ideas? January 09, 2019 09:34AM |
pomponX
