printer take much time to get temperture
Posted by holala02
January 01, 2019 07:37AM
hello guys and happy new year.
i have an ANET A8 full upgrade:
4 fan
3 extruders
bluetooth module
and ramps1.4 with screen...
i have a power supply 650W but i take much times to get 190°C :/
why please
picture link : [imgur.com]
Edited 2 time(s). Last edit at 01/01/2019 07:38AM by holala02.
Re: printer take much time to get temperture
January 03, 2019 11:49AM
Did you do pid auto tune?
Kind regards
Imqqmi
NFAN CoreXY printer:
[reprap.org]
January 07, 2019 08:13AM
Note that the PSU shows the total available power across all outputs.
The 12V lines are only rated to 19amps . 19 x 12 = 228watts.
That sounds enough but if you run a hot bed at 130 watts plus 3 hot ends at 30watts thats 130 + 90 =220 so you are borderline given you still have to run the controller, motor, fans.
Also you have a current limit on the control board so you need to check the driver is adjusted correctly. I can't remember how you do it on a ramps but i think you run the system on 5V and adjust a potentiometer to read about 0.4volts.
Also ensure the fan is not blowing on the hot end.
Hopefully someone else will jump in with some help.
January 17, 2019 07:55AM
On the other hand, when the heated bed is heated up, the current draw drops due to increased resistance at higher temperatures. I've measured my 24V bed at 8A when cool, and drops off to 5A when almost at the set temperature (before PID kicks in, lowering the current draw on purpose). If you open up the psu you can check if there's more than one 12V output on the psu and split the bed and other parts between them.
Usually the bed heats up first, then when PID kicks in, the current draw drops, so it shouldn't be too much of a problem.
Kind regards
Imqqmi
[reprap.org]
January 17, 2019 09:31AM
Any insulation under the heated bed? Without that your just trying to heat up the air.
Also putting insulation on top of the bed till it gets close to temp helps a lot
