Hello.
I just purchased the E3D Titan extruder to be used on my new CoreXY printer. I bought it because of the versatile mounting options, and because it can be used easily with both the V6 and a bowden-style setup... or so I thought. I've followed the exact assembly instructions on the E3D website, however, whenever I try to extrude (even with the idler pressure on the lowest possible setting), the filament gets too grooved to pass freely in the bowden tube. In fact, just heating the hotend to 210 degrees (the recommended setting from the manufacturer of the filament) and attempting to extrude a small amount of 1.75mm PLA will result in the extruder grinding away on the filament because it simply cannot push it through the bowden tubing.
I know that this is the problem because taking a 20 cm piece of filament that has gone through the extruder, and attempting to push it through a 20cm piece of tubing (even without a hotend on the other side) is very challenging. The filament is simply too grooved and grinded.
I have attached a few images of the filament after going through the extruder, and also of the extruders hobbed "bolt"/gear.
Has anyone else experienced anything like this? What have you done/what can you suggest?
I have thought about grinding down the gears "teeth" a bit, so they won't cut into the filament as much, but I don't know if that will work and I don't want to damage the extruder...
BTW the filament is white InnoFil 1.75mm PLA.
Thanks in advance!
