I have a clone prusa I3 running a ZRIB board.
Recently the auto level sensor conked out, it was a slow process beginning with it losing accuracy, and then ultimately being stuck on.
I ordered the following sensor to replace it (with the same specifications)
New Sensor
The new sensor doesn't seem to work - It does not actuate on when I manually touch it to the bed or any metallic object, and when I run an auto home, instead of the Z-axis moving down towards the bed, it rises upwards a few millimeters, and then starts printing.
I am wondering if it is not a problem with the sensor, but a problem with the board? Is there a way of manually checking the sensor with a DMM?
In the meantime, can I remove the auto-level code from my firmware? If I do how will the printer Home the z axis? Do I need to install a limit switch? I have never seen a non auto-level printer in person so I do not know how they home.
Also, any recommendations on new electronics (board/drivers and LCD control) to run my system is appreciated, I don't think this Zonestar ZRIB board is too popular, so I would ideally like to swap to something more user friendly with more online information and support.
Any help appreciated!
