Sequential layer dimension change April 16, 2019 02:18AM |
Re: Sequential layer dimension change April 16, 2019 03:44AM |
Re: Sequential layer dimension change April 16, 2019 04:04AM |
Re: Sequential layer dimension change April 16, 2019 06:49AM |
Re: Sequential layer dimension change April 16, 2019 07:52AM |
Re: Sequential layer dimension change April 16, 2019 08:45AM |
the_digital_dentist
Z wobble offsets the layers so that on one side of the print any given layer will bulge and on the opposite side it will create a concavity, like very small layer shift. That looks more like the layers are not consistent thickness.
Id the bed heated and is it using bang-bang control?
MCcarman
What is the connection between the lead screw and the motor?
looks a bit like something is winding up then suddenly releasing. If the bed is not free to slide in Z and the connector is of the flexible type it might be winding up the connector until the load is high enough to release.
If you have the flexible spiral type connector I suggest making sure the motor is pulling the connector around with increasing Z.
Re: Sequential layer dimension change April 16, 2019 09:24AM |
Re: Sequential layer dimension change April 16, 2019 09:51AM |
Re: Sequential layer dimension change April 16, 2019 11:00AM |
Re: Sequential layer dimension change April 17, 2019 04:59AM |
Re: Sequential layer dimension change April 17, 2019 07:53AM |
Re: Sequential layer dimension change April 17, 2019 01:14PM |
