Spacing between shells May 30, 2019 01:54PM |
Re: Spacing between shells May 30, 2019 02:24PM |
Re: Spacing between shells May 30, 2019 04:41PM |
Re: Spacing between shells May 30, 2019 05:45PM |
To me it looks like you are underextruding or have an axis that isn't calibrated.Quote
carro
Hi all.
Perhaps someone knows what's happening here on attached photo.
Printed in PLA on a delta with 0.4mm nozzle, 0.2 layer height @ 205*C hotend and 65* bed, Marlin 2.
Slic3r'd with 3 perimeters, 3 bottom and 3 top layers, 30% infill, and 75% infill/perimeters overlap (upped from default of 55%).
As far as top layer goes - the dude's arms have 100% infill and look good enough i guess, his legs not so much but probably just not enough infill?
The uneven gaps between perimeters and infill, and between actual vertical shells are a mystery to me though. Tried upping the overlap but it had no discernible effect and as far as i can tell I'm not underextruding.
Regards,
Peter
Re: Spacing between shells May 30, 2019 06:28PM |
Re: Spacing between shells May 30, 2019 07:50PM |
the_digital_dentist
Don't calibrate with 20mm cubes. They are too small to calibrate anything because extrusion errors can make up a relatively large portion of the dimensions. Print the largest object you can reliably measure. The diagonals of a 100 mm cube/square can be measured with a common 6"/150mm caliper.
Re: Spacing between shells May 31, 2019 09:47AM |
Re: Spacing between shells May 31, 2019 10:10AM |
Re: Spacing between shells June 01, 2019 06:28AM |
Re: Spacing between shells June 01, 2019 10:21AM |
