Cura Temperature
Posted by dlw
dlw
Cura Temperature
June 01, 2019 11:48PM
How is the temperature changed in Cura?
Printing PETG at 215c and the temperature need to be higher.
dlw
Re: Cura Temperature
June 02, 2019 03:44AM
In Cura 4 it's in the material tab.
But what version are you using?
http://www.marinusdebeer.nl/
dlw
June 02, 2019 07:01PM
Cura 4.
Found temperature in materials.
However, it can not be changed.
The temp is set at 215c as default.
Any ideas?
dlw
June 03, 2019 04:43AM
Okay, maybe it gets the value from your materials library.
Click the gear at the materials tab when you hover it, the gear appears.
This opens up the settings, you can here choose to go to the materials tab and edit the specific temp settings for the material you're using.
Select your material and move to print settings, here you can define the default temp for your filament.
Does this help?
dlw
June 03, 2019 09:56AM
It's the default.
Can not change.
See attached photo.
Problem solved.
Chose a different supplier.
Found one with 235c.
This did not work.
Created a custom temp setting.
So far, it is running.
Thanks for your help.
dlw
Edited 3 time(s). Last edit at 06/03/2019 10:35AM by dlw.
open | download - petg.PNG (29 KB)
June 03, 2019 10:53AM
dlw
It's the default.
Can not change.
See attached photo.
Problem solved.
This did not work.
dlw
Ahhh yes, the generic profiles, it's indeed better to create a custom one. I'm glad you solved it! smiling smiley The FormFutura profile in my Cura 4 is also a custom profile. I just made it myself and only later found out I could add their profiles through the Marketplace.
Edited 1 time(s). Last edit at 06/03/2019 10:54AM by Ohmarinus.
