Problem nema23 tb6600 Marlin June 28, 2019 04:53AM |
Re: Problem tb6600 Marlin June 28, 2019 05:01AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Problem tb6600 Marlin June 28, 2019 05:48AM |
Admin Registered: 15 years ago Posts: 7,315 |
Re: Problem nema23 tb6600 Marlin June 28, 2019 06:15AM |
Re: Problem nema23 tb6600 Marlin June 28, 2019 10:37AM |
Admin Registered: 18 years ago Posts: 14,166 |
Re: Problem nema23 tb6600 Marlin July 01, 2019 02:04AM |
STEPPER_DRIVER_TYPE for your axes to "TB6600" then you might also try "DRV8825" which sets a 2µs pulse length. Keep your accelerations low as you get into testing, and see if you can find a range of stepper pulse durations and accelerations where you get no layer shifting. Don't forget to do M500, M502 after re-flashing.Configuration_adv.h file.|
Re: Problem nema23 tb6600 Marlin July 01, 2019 02:42AM |
Thinkyhead
Marlin bugfix-2.0.x supports a variety of stepper drivers, including the TB6600. If you've already set theSTEPPER_DRIVER_TYPEfor your axes to "TB6600" then you might also try "DRV8825" which sets a 2µs pulse length. Keep your accelerations low as you get into testing, and see if you can find a range of stepper pulse durations and accelerations where you get no layer shifting. Don't forget to doM500,M502after re-flashing.
If that doesn't do the trick, you can manually override the stepper-driver-based pulse durations in theConfiguration_adv.hfile.
Re: Problem nema23 tb6600 Marlin February 02, 2020 09:42AM |
