Nozzle cleaning
Posted by Seapeace
Nozzle cleaning
August 09, 2019 08:39AM
After having printed something, the filament gets solidified in the nozzle and also in the hotend barrel. I tried a few times to keep printing without cleaning them but could not go through. The nozzle was clogged. Is there a way to print other jobs without cleaning (which is quite hard and time consuming) ? For example, would it work if I add a line in the gcode after heating the hotend, to push the filament 10-15 cm without doing any motion, then start the normal gcode ?
Re: Nozzle cleaning
August 09, 2019 01:25PM
Prime extruder example 4mm filament
This is probably already in your slicers startup G-Code.
G1 E4.0 ;prime extruder
